8mm m8 threaded rod
This topic contains 10 replies, has 3 voices, and was last updated by  Ryan 1 year, 6 months ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Author
    Posts
  • #26351
    James VanDusen
    Participant
    What lock nut do I need for this rod?
    I tried 8m x 1.25 and the pitch is wrong…
    #26352
    James VanDusen
    Participant
    This is to replace the 5/16 rod with a typical reprap rod…
    #26353
    James VanDusen
    Participant
    Yikes and I met coupling nut
    #26354
    Mic Vee
    Participant
    I believe that M8 only comes in two pitches – 1.25 is coarse, and 1.0 is fine pitch. Someone can correct me if I’m wrong, but I would get M8-1.0 for the Z axis. That means that your threads are 1.0mm apart (I hope I’m not over explaining – I just try to be thorough).
    #26356
    Mic Vee
    Participant
    FWIW – for Imperial hardware the Parts page says to use 5/16-18 which is the coarse thread version of 5/16 – https://v1engineering.com/blog/parts
    You will have to adjust your firmware either way, so maybe it doesn’t matter. I believe I have fine pitch for the Z axis.
    #26359
    James VanDusen
    Participant
    Where do I get the coupler for the lead screw m8? I only have seen m8 – 1.25 which does not work
    #26366
    Mic Vee
    Participant
    I think I misunderstood you. Are you trying to use a lead screw or M8 threaded rod with a coupling nut?
    If you are talking about a lead screw, you could try this thing along with a lead screw nut, but I have no idea if it would work since the designer hasn’t even tried it: http://www.thingiverse.com/thing:1727299
    (On that note, I can’t find a M8-1.0 coupling nut. I would just buy threaded rod that is M8-1.25, or stick with 5/16.)
    #26707
    James VanDusen
    Participant
    All
    I was able to fix this by purchasing a 8mm 2mm pitch lead screw on amazon. It came with the coupler (round).
    https://www.amazon.com/gp/product/B016W5NHY2/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    T8 300mm 8mm Lead Screw with Coupler
    I then bored out slightly the top piece for the Z carriage assembly and inserted the coupler into the top. This prevented the restraining bolt to completely screw down, but it was through the whole assembly and allowed rigidness.
    See Pictures of the assembly with the coupler and lead screw installed.
    Firmware
    I had to update the firmware for the Z steps reducing to 800.
    I then added grease to the lead screw and ran it up and down a few times. raising it 160mm each way. This allowed pushing the grease through all the threads.
    I the lowered it and zeroed it as we normally do…
    Did a test print – Viola! perfect horizontal prints… wow in fact you cannot see the lines at all… barely at .2mm
    RECOMMEND this solution over the supplied 8mm or 5/16 solution… as its ridged enough to never be bent and is incredibly accurate.
    #26721
    Ryan
    Keymaster
    Before you recommend it make sure it works with a heavy router and you have a look at the FAQ’s.
    #33479
    James VanDusen
    Participant
    All
    Firmware
    I guess my actions proved themselves.. Ryan is now promoting this solution lol
    #33482
    Ryan
    Keymaster
    The positives now outweigh the negatives, from a production standpoint. A bunch of you have been using lead screws now, a few since day one. None of you have complained about the need to constantly replace the brass nut so I feel they must last long enough to not worry too much about it as a consumable part. A vast majority do not have any issue with the allthread and can easily save some money by using the easier and cheap to source allthread.
    Cheap leadscrews still bend or come bent, accuracy has a price. Lead Screws with a certified straightness cost about as much as the full kit.
    I am still very careful not to say this is the best way, just the way I chose to sell future kits. I have written a fairly long post about this. Ballscrews are still the correct way to do this, allthread is the easiest, leadscrews are the sweet spot in the middle.
