80mm Mount
This topic contains 10 replies, has 7 voices, and was last updated by  Matthias 3 months ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Author
    Posts
  • #87657
    Thomas
    Participant
    Hello everybody,
    I’m just building a mpcnc. I am nearly ready with everything. The only problem i actually have is the mount for the spindle. Does Anybody have a rigid mount for an 80mm Air cooled Spindle? What material ist best for Printing? PETG because of heat of the spindle?
    Thanks for helping.
    Thomas
    #87661
    Barry
    Participant
    Umm, how many watts is that thing?  The only 80mm spindles I can find are the big guys that run off a vfd.  If that’s what you have, I don’t think I’ve seen one on a mpcnc yet.
    What do you know!  There’s one on thingiverse.
    https://www.thingiverse.com/thing:1964028  It will take a few modifications, so read up on the summary.
    1 user thanked author for this post.
    #87663
    Thomas
    Participant
    it has 1.5 kW .  yes it has a vfd just because of better torque in lower rpms. This one on Thingiverse is for the watercooled version. I think it won’t work with my aircooling. But i’ll give it a try.
    #87664
    Thomas
    Participant
    #87669
    WarHawk8080
    Participant
    You can order a fairly cheap metal one
    #87678
    David Walling
    Participant
    How much does that thing weight? I know Ryan has concerns with a lot of weight on the Z axis on the MPCNC. I’d compare the weight of your spindle to the weight of the dewalt before commiting to that spindle.
    Looks like the dewalt weights 3.2 lbs
    #87742
    Guffy
    Participant
    I had printed almost entire mpcnc from pla, but tool mount from abs. Because abs works up to 80-100C.
    Petg up to 60-70. Pla 50
    #88138
    Jutoto
    Participant
    It’s not just the weight, but the size to pay attention to. Because, by the fact that the same weight more distant from the axis will add more effort on the gantry.
    As I can not order the dewalt dw660 in France I use for the moment a cheap model (55$) of standard diameter 65mm while waiting to buy a Kress much more expensive.
    It weighs the same weight as the dw660 but it is a bit more bulky that’s why I drew a tool holder where the spindle  is the closest to the MPCNC tool mount part.
    defonceuse_tool_mount_65mm
    Vanhaus-65mm-spindle
    vanhaus-defonceuse-dessus
    As you can see, it’s very close to bolts.
    and I see that this is also the case for the one Barry told you
    If you need I can do something similar for 80mm tool
    #94161
    Matthias
    Participant
    Project done?  I have ordered a 1,5Kw 80mm Spindle with Vfd, too. But now I’m not sure if  it fits to the MPCNC.  4.6 kg are maybe much for the 25mm  tubes?
    #94220
    Barry
    Participant
    That’s got a little bit of gravity to it!
    #94236
    Matthias
    Participant
    I have a workspace of 600x900mm… in the middle of X and Y, the  rails goes 0,42mm down? .. too heavy ….
