26.7 Galvanized pipe
New Home Forum Mostly Printed CNC – MPCNC Advice – MPCNC 26.7 Galvanized pipe
This topic contains 1 reply, has 2 voices, and was last updated by  Ryan 5 months ago.
Viewing 2 posts - 1 through 2 (of 2 total)
  • Author
    Posts
  • #103744
    Conrad
    Participant
    There’s some awesome galvanized pipe at Lowe’s that I thought would be perfect for this project, it’s thick walled and very rigid but when I  mic’ed it the OD is 26.7.
    Has anyone used pipe this size?  Are there slightly bigger part .stl files?  Did someone scale up the parts 5%?
    Thanks,
    Conrad
    #103767
    Ryan
    Keymaster
    Makes the bolt holes bigger as well, so it doesn’t really work that easy. Then the Z axis will be all kinds of wonky. We tried with 25 to 25.4…didn’t work well enough.
    I am sure you will get a usable machine but not sure what other issues will pop up.
