25.4 mm Conduit
This topic contains 5 replies, has 4 voices, and was last updated by  Bill 1 year ago.
Viewing 6 posts - 1 through 6 (of 6 total)
  • Author
    Posts
  • #26766
    Marcos
    Participant
    Hello, gentlemen
    I have a serious problem, I can not get 25.4mm conduits in Texas.
    Try at Lowes and at Home Depot, also at some local stores.
    Every time I measure the 1-inch pipes all give a reading of 27 mm …
    I live in Mcallen, someone bought the pipes by amazon or some page ??
    Thanks
    Marcos
    #26767
    Ryan
    Keymaster
    Counduit is not 25.4…That is for stainless OD tubes. If you are using conduit you should buy 3/4″ conduit the OD of it will be 23.5.
    #26769
    Marcos
    Participant
    I want to build a very strong rigid structure.
    Okay, I’ll keep looking for the stainless OD tubes
    #26788
    Jeffeb3
    Participant
    In Colorado, I found some at a “metal supermarket”. But I’m sure there are other metal suppliers in Texas.
    #26803
    Marcos
    Participant
    Thanks
    Which of the options do you recommend?
    Find one in Austin … it’s the closest
    #26834
    Bill
    Participant
    You will find that one of those thicknesses will be substantially cheaper than the rest. Choose it. 🙂
