24"x42" J Tech Laser/Router build in GA
New Home Forum Mostly Printed CNC – MPCNC Your Builds – MPCNC 24"x42" J Tech Laser/Router build in GA
This topic contains 65 replies, has 8 voices, and was last updated by  Tim 2 months, 4 weeks ago.
Viewing 6 posts - 61 through 66 (of 66 total)
  • Author
    Posts
  • #105003
    Ryan
    Keymaster
    Looks pretty good though! I giant circle is by far the most dimension critical thing you can do, so for a first run of something so big, I’ll give you a 99/100.
    1 user thanked author for this post.
    Tim
    #105004
    Tim
    Participant
    Even harder because it’s a 24″ circle and my machine is 24″ cutting area, so I couldn’t use hard stops and have the file be 24″. But I’m pretty happy with it, I think dual endstops are in my future…
    #105138
    Tim
    Participant
    Expectation
    Reality
    Didn’t have time to coat it in anything before doing the resin (my flight leaves at 3:00 tomorrow afternoon) so I went for it….
    Didn’t turn out half bad.
    Should note this is vcarved not pocketed. I loooove the finish vcarving leaves straight off the machine.
    After taking that pic, I took a finger nail brush and rubbed it across the vcarved areas and it actually cleaned it up even more. Just a stiff nylon brush. Funny how soft pine is.
    Another one bites the dust.
    #105159
    Barry
    Participant
    Probably the hardest part is getting the thing level!  I made Shaneh a penny table for her office(bookkeeper), thought I had it level, I was slightly wrong.  Took way more pennies than I thought it would, had to go back to the bank twice!  Also took more glaze coat than I thought, ended up with 3 quarts, still have an unopened box in the barn because we didn’t want to go back again.
    https://photos.app.goo.gl/AXXvroNVAWZU1G8Q2
    #105163
    Tim
    Participant
    lol right! I don’t think there’s a perfectly level surface in my entire house. I want to try another sign with a glaze coat over the whole thing soon.
    That looks very nice!
    #106820
    Tim
    Participant
    Tangentially related to MPCNC so gonna post it here, lol. Maybe someone else will be able to make use of it.
    I like to record my projects and then post them to Instagram… and hopefully some YouTube here soon.. but I sold my nice camera gear a couple years ago (had a $300 carbon fiber tripod, Sony A6000, a bunch of lenses… wish I never got rid of them, especially the tripod!)
    But this is 2019 and I’m a firm believer in “the best camera is the one you have with you”–so my iPhone is good enough. And actually, I find the ease of speeding up a video and posting it straight to Instagram or Facebook verrrry nice. I actually did buy another A6000 a month or so ago, but I’m not using it for video for that reason.
    Anyway. I found this iPhone XS tripod mount on Thingiverse, printed it out… and it didn’t fit at all. Not even close. I found if I scaled it to 95% it fit. My printer is pretty dang accurate now so I’m thinking the guy who designed the original has a printer that may not be… Anyway, the original was designed for the 1/4-20 from the tripod to just form its own threads into. I don’t find that to be a very robust solution, so I decided to open up the STL in Fusion, change the hole size to the recommended drill size for the inserts I used on my spoilboard (threaded 1/4-20, sweeeeeet) print it out.. and everything was good. Except the 1/4-20 stub on the tripod is only like 3/16″ long, and the first 3/16″ of the threaded insert is unthreaded because it’s cut out to fit an allen key. So I threaded it in so that part was sticking out and cut the allen key bit off with my jigsaw. And it works great!!
    Kinda happy with how I hacked this together as cheaply as possible–I got the tripod on Amazon (Amazonbasics) so it was around $15… and plenty good enough to hold a cellphone.
    Have some other stuff in the pipeline, but it’s about to get crazy busy at work (huge semiannual event coming up in a month) so we shall see when I get to it.
