23 Oct. 2019 Firmware missing menu item
New Home Forum Mostly Printed CNC – MPCNC Troubleshooting – MPCNC 23 Oct. 2019 Firmware missing menu item
This topic contains 7 replies, has 3 voices, and was last updated by  Jeffeb3 1 week, 5 days ago.
Viewing 8 posts - 1 through 8 (of 8 total)
  • Author
    Posts
  • #119584
    Victor D.
    Participant
    I updated the firmware on my Rambo 1.4 with dual endstops from the April (I think) to the 23 October version; however, now I no longer have the option to save my settings/configuration (e.g., calibrating X, Y, and Z steps/mm); therefore, I loose the configuration every time the machine is turned off.
    Am I missing something? I looked for it in other menus too but not there.
    Thanks,
    Victor
    #119590
    Jeffeb3
    Participant
    Sounds like EEPROM is turned off. It should be in the Configuration.h
    1 user thanked author for this post.
    #119593
    Ryan
    Keymaster
    Dang it it is off again, it got moved so that kicked out my setting….grrr So many changes.
    #119603
    Jeffeb3
    Participant
    What about putting one or all the configurations in the examples folder in the main Marlin? I think thinkhead has a way to keep those up to date when he does changes. At least, you’d have a better vanilla place to start from.
    #119606
    Ryan
    Keymaster
    I have everything based off of a ramps profile from there there are not many changes to each branch, but if I miss a change it happens to all of them. Right not they are messing with a lot of things so I am hesitant to update right now and making the eeprom change to all of them just for that is kind of a lot of work. Hopefully they slow down again or hit the RC/release mark soon.
    #119608
    Victor D.
    Participant
    Is this the line you’re talking about:
    //#define EEPROM_SETTINGS // Persistent storage with M500 and M501
    Thanks,
    Victor
    #119609
    Victor D.
    Participant
    On the bright side, the spindle control, that was not working before, is now working!!
    #119610
    Jeffeb3
    Participant
    Yep.
