20×30 inch build
This topic contains 31 replies, has 9 voices, and was last updated by  Ryan 2 years, 9 months ago.
Viewing 30 posts - 1 through 30 (of 32 total)
  • Author
    Posts
  • #3441
    karltinsly
    Participant
    I have been working on my CNC for about three weeks, starting with printing all the parts. Here they are:
    Printed parts for my MP CNC
    I also printed parts to use my angle grinder as a cutoff saw for the conduit:
    My angle grinder chop saw.
    Here’s my nearly-completed machine. I’ve just gotten the axes moving using the LCD, but I think I need to get a real drive coupler to get the z axis working better.
    Nearly completed CNC
    CNC in its new home.
    Still need to get it bolted down in its new home, and then start learning to use the CAM software.
    Thanks, Ryan, for making this journey possible for me!
    Karl
    #3443
    karltinsly
    Participant
    Hmmm. Where are my pictures? I used the img button to link to the pictures on dropbox. They’re in a public folder. How do I make my pictures show up?
    #3444
    karltinsly
    Participant
    Maybe as attachments?
    #3446
    karltinsly
    Participant
    #3451
    Asho777
    Participant
    Nice work, it all looks good to me.
    I’m almost at the same stage, a couple more prints to do, then play around with the electronics before full assembly.
    Cheers
    Greg.
    #3456
    SteveC
    Participant
    Note that a regular pipe cutter works on steel conduit. You just have to go around it many times and need strong hands.
    I love the grinder chop saw!
    #3459
    Ryan
    Keymaster
    I really could have used the little chop saw print when I was building the 4 head printer. Cut so many pieces I had to get a new hacksaw blade.
    #3467
    karltinsly
    Participant
    Northern Tool has a similar mount for an angle grinder chop saw, but I could never bring myself to spend the $25 or so for something I wouldn’t need very often. Then I saw this: http://www.thingiverse.com/thing:317474. Worked perfect for my application. The clamp I printed was a little large for my harbor freight grinder, but I just wrapped in a strip of rubber pond liner I had laying around. The clamp can be sized to fit, though. Wear safety glasses!
    #3492
    rovida
    Participant
    Hi Karltinsly, could you please tell me where I can download the attach you have in your pictures 2015-10-10-15.48.47-Medium.jpg ?
    Many thanks
    #3493
    karltinsly
    Participant
    Hi Rovida,
    Do you mean the angle grinder mount? It’s http://www.thingiverse.com/thing:317474.
    If not the grinder mount, what are you referring to?
    Karl
    #3498
    Ryan
    Keymaster
    I believe everything in the picture you are referring to are standard MPCNC parts.
    Parts
    http://www.thingiverse.com/thing:724999
    #3545
    karltinsly
    Participant
    SUCCESS! I finally got everything ironed out and had my first successful print (with a sharpie in the tool holder). Tomorrow I hope to do my first cut!
    Can I embed a video here?
    <iframe width=”560″ height=”315″ src=”https://www.youtube.com/embed/kAzwxIWznHI” frameborder=”0″ allowfullscreen></iframe>
    If that doesn’t work, here’s a link: https://youtu.be/kAzwxIWznHI
    Woohoo!
    Karl
    #3548
    karltinsly
    Participant
    Trying one more time to embed the video.
    #3574
    karltinsly
    Participant
    Made my first cuts!
    #3586
    karltinsly
    Participant
    Used a 1/2 inch harbor freight end mill, 15mm/s feedrate, 1mm depth, 65% step over. Next time I do one of these, I will oversize the slot so it can be cut with the 1/2 inch bit and still fit the t-slots, and I’ll also put the two boards together and cut the slots for both at the same time (just set the depth to 31mm). I might also speed it up some – either faster feed rate or deeper cuts. But I shouldn’t need to do this again for awhile.
    The only thing left is dressing the bed.
    These t-slots are awesome! They take 1/4-20 carriage bolts, which are cheap and readily available. I couldn’t find a 1/4-20 knob with a trapped nut, so I remixed my own. Here’s what I used:
    T-slots: http://www.thingiverse.com/thing:876395
    Clamps: http://www.thingiverse.com/thing:21057
    Knobs: http://www.thingiverse.com/thing:1071520
    #3588
    Ryan
    Keymaster
    Nice, added them all to the videos page. Congratulations.
    #3938
    karltinsly
    Participant
    Meant to be test cuts, but they came out so well, we’ll probably use them! Really liking the carve feature of ESTLCAM. I’ve used a 1/2 inch 90 degree and 1/4 inch 60 degree bit so far. I’ve ordered a set of 10, 15, 20, and 30 degree bits for finer work.
    Getting your z-zero correct is key, especially for carving. I find it’s better to be too deep that than not deep enough, so I usually set my zero a few tenths of a mm below the surface.
    #3941
    Ryan
    Keymaster
    looks like someone is about to have the machine pay for itself pretty soon. Those signs cleaned up really well. Thanks for the new vid and the inspiration to try the esltcam carve feature.
    #3948
    karltinsly
    Participant
    The machine paying for itself would be great! I’m a ways from that but working steadily towards it. I also want to try this:
    https://youtu.be/8YpjPi2QanQ?list=PLRK7iJu0LNR2SUYFXWXBNPtl3Bwxa6IgU (carving bas relief)
    If anyone knows where I can get a good bas relief file of a llama or alpaca, please let me know!
    Karl
    #3954
    Curt
    Participant
    GREAT WORK!!
    Can you please share a few things? Which dust collector head is that? Are the files available on thingiverse? What OD did your use for the sharpie holder? What cable chain did you use? Printed or purchased?
    I recently ordered the carving bits and hope to get them soon.
    Curt
    #3961
    karltinsly
    Participant
    Thanks, Curt! The dust collector is the one that PCFlyer created for his spindle. I created an adapter that will mount it to the DW660. You can find more details here: http://www.thingiverse.com/thing:1091450.
    The sharpie holder was something I threw together on tinkercad. I’ll try and attach it here.
    The cable chain was purchased on Amazon: http://www.amazon.com/gp/product/B00880AVL2?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00. I ordered two of them. I didn’t want to spend all the time needed to print them, especially because I knew they wouldn’t be as strong and reliable as the molded ones.
    Karl
    #3962
    karltinsly
    Participant
    Hmm. Wouldn’t take the .stl file. I’ll try a zip.
    #4019
    Simon
    Participant
    Areyou having scaling issues with ESTLCAM? When I take files made in inches from autocad to ESTLCAM as .dxf there is a downscale of who knows what factor. I have ESTLCAM set to import inches and my machine export mm. Not sure, but thought you might have the answer as you are in the US and probably use inches.
    Thanks
    Simon Packman
    Also your setup looks great. You make me want to clean up my workspace.
    #4022
    Ryan
    Keymaster
    I use mm, so I have not run into this. Is it importing them wrong or exporting them wrong?
    My only suggestion would be to take it off inches and tell it to ask every time on import.
    #4028
    karltinsly
    Participant
    The only scaling issues I had with ESTLCAM was with SVGs out of inkscape, which turned out to be a problem with SVGs. I’ve not had any problems with DXF out of inkscape or visio. I do save with mm as the unit of measure.
    Thanks for the compliment on my “clean” shop. Don’t tell anyone, but the camera is pointing at the only tidy spot in my garage!
    #6169
    karltinsly
    Participant
    Not very long or detailed, but here’s a short video of my MPCNC lasing some leather. Worked okay, but I need to spend some more time on it to get the quality of the burn up.
    #25201
    karltinsly
    Participant
    Almost exactly a year since I last posted in this thread! ‘Bout time to revive it. You know you’ve been around when you find your old post less than 20 threads from the very beginning!
    I’m getting close to getting my upgrade finished. The new build has the new middle section (MUCH stiffer! Thanks, Ryan!), the new rollers, a gantry-mounted vacuum shoe (not quite finished yet, but I got the mount on the gantry), and gantry-mounted terminals for the Z axis.
    There will be some new electronic bits, too. In addition to the separate button controller, posted somewhere else here on the forums last year, there will be an updated version with more buttons for specialized functions and tool control, and a PID speed-controlled spindle.
    I have some other things planned, as well. I’ll post pics as it starts to come together.
    As always, thanks Ryan, for a great machine!
    #25202
    Ryan
    Keymaster
    Thanks and glad to see you back at it.
    #25203
    Zeenon
    Participant
    When you guys post the dimensions of your builds, is that working area?
    Z
    #25217
    karltinsly
    Participant
    I can’t speak for everyone, but in my case, yes, it’s the working area.
