17w laser, seem legit?
This topic contains 41 replies, has 9 voices, and was last updated by  Barry 1 year ago.
Viewing 12 posts - 31 through 42 (of 42 total)
  • Author
    Posts
  • #53948
    SteamPunkProgrammer
    Participant
    That is how I added it to my Co2. You need more pressure than a fan can deal with. It works very well and keep your lens perfectly clean. I just 3d printed a cone that fit on my laser, came down to a ~3mm hole, had a barb on the side that fit surgical tubing, and that went down to a large aquarium pump I got from amazon. A bunch of the k40’s do it that way that way there is nothing to adjust. If the laser can see it so can the air stream. Pumping air in from the side means certain directions work better than others.
    I think he’d be okay with the fan he has, it’s a centrifugal blower fan. I have three smaller ones on my 3d printer, can’t let them get over 25% or they blow too much and cool the hot end down. He could go crazy and add one on the other side, duct both into a cylinder that’s open at the bottom and seals up against the laser lens assembly. Could get really fancy and duct them opposite of each other so you get a swirl in the air stream. That should kick out any particulates that might foul the lens.
    Using two blower fans is my idea going forward, and designing a kind of duct system just as you said creating a swirling air stream down a cone just as Ryan said.
    There was a design on thingiverse that used a fan and he said he was going to change to tubing because the fan was recycling the smoke once he started really cutting a lot.
    I thought of a solution for this as well, the intake for the fans will be up out of the way ensuring fresh air is pulled however just one fan on the side of it as a quick test in my video solved the smoke blow back problem pretty much completely; So I’m not very worried the fans would be blowing back in smoke. I did use this for a much longer cut that took over an hour and had no issues.
    #54334
    SteamPunkProgrammer
    Participant
    Hey ryan; could you point me to your test script for lasers, I had it at one point but cant seem to find it again 😐
    #54336
    Ryan
    Keymaster
    Quick focus.
    How To
    #54408
    SteamPunkProgrammer
    Participant
    Quick focus.
    How To
    <iframe class=”wp-embedded-content” title=”“How To” — V1 Engineering” src=”https://www.v1engineering.com/information/how-to/embed/#?secret=LcpjL8HMga” width=”600″ height=”255″ frameborder=”0″ marginwidth=”0″ marginheight=”0″ scrolling=”no” sandbox=”allow-scripts” data-secret=”LcpjL8HMga” data-mce-fragment=”1″></iframe>
    Thanks much! was finally able to tune the beams focus in, sneak peak, I was waaaay off. lol
    #54412
    Ryan
    Keymaster
    Dang so you have more power!? Do you have to focus them individually?
    #54414
    SteamPunkProgrammer
    Participant
    MUCH more power, I was somewhere between 10-15mm off, so it was a huge difference, and I needed to speed the laser up because it got to the point the wood would just catch fire instead of cut haha. Don’t need to adjust both there focus range is shared but it seems pretty tight, 3-4mm or so.
    #55594
    SteamPunkProgrammer
    Participant
    I finally got some more time to make another video with the laser, definitely showing how useful it is!
    https://youtu.be/W0fkDJNkzJQ
    #55596
    Ryan
    Keymaster
    I have not watched the video yet so I am not sure you mentioned it in there but vinyl is a no no with a laser. Poisonous gas is created. I took my vinyl video down.
    #55597
    Ryan
    Keymaster
    Acrylic is okay but the other ones are not.
    http://atxhackerspace.org/wiki/Laser_Cutter_Materials
    #55598
    SteamPunkProgrammer
    Participant
    oh well crap, haha..well I’ll figure out some way of recovering the video. glad I use lots of air filtering and only cut for a few minutes!
    #55605
    SteamPunkProgrammer
    Participant
    Okay, I added a warning to the beginning of the video to make it clear you shouldnt do that, lol.
    #55701
    Barry
    Participant
    Hey, what is the size of this laser assembly?  Would one of these fit?
    https://www.thingiverse.com/thing:2832127
