16T GT2 10mm Pulley
New Home Forum LowRider Troubleshooting – LowRider 16T GT2 10mm Pulley
This topic contains 6 replies, has 4 voices, and was last updated by  Bas Goossen 3 weeks ago.
Viewing 7 posts - 1 through 7 (of 7 total)
  • Author
    Posts
  • #115167
    Josh
    Participant
    Has anybody ran into the issue where the pulley doesn’t fit on the stepper motor.  I’ve backed out the screws completely and it doesn’t fit.  I thought about hammering it on, but I feel that’s a bad idea.  Filing down the inside?  or just go ahead and buy an extra one for a few bucks?  The other ones fit nicely, its just this one is being a pain.
    Respectfully,
    Josh
    #115170
    Ryan
    Keymaster
    Make sure there is not a bur near the grub screw hole, other than that you can probably tap it on and be okay. The only way it should not fit would be drastic, 3mm or 6 mm hole
    1 user thanked author for this post.
    #115179
    Josh
    Participant
    Thank you, I do see a spur.  I’ll tap it on there gracefully!
    Respectfully,
    Josh
    #115185
    Ryan
    Keymaster
    Well I can’t tell for sure by the hand but if you are AvE you better take it easy with the tappy tap tap…
    #115186
    Ryan
    Keymaster
    J/k always scared of people’s version of gracefully.
    #115188
    frosty
    Participant
    Be very gentle tapping on the stepper shaft. The motor bearings aren’t really designed for axial shocks. I’d recommend pressing on with a C-clamp.
    #115450
    Bas Goossen
    Participant
    I had this issue with the leadscrew couplers. Just put a screw in on one of the side holes (2 turns or so) just so that it is not getting in the way for some holding grip. Than take it to the drill press if you have one. Dril them out to fit with a proper drill.
