1/16" end mill setting
This topic contains 3 replies, has 2 voices, and was last updated by  Ryan 4 months ago.
Viewing 4 posts - 1 through 4 (of 4 total)
  • Author
    Posts
  • #46345
    Larry McCaughn
    Participant
    I have a “standard MPCNC setup
    I’m wanting to do some 1.5mm pocket  milling using Estlcam cam  with my 1/16” end mill in pine
    What’s a good horizontal speed? Vertical speed? stepover %?
    I don’t want to snap the bit on my first try with a bit that small!
    TIA
    LarryMc
    #46346
    Ryan
    Keymaster
    You should start in foam, have you cut anything else? Is the pen plotting perfect?
    Start with an 1/8″ bit, to get a good grasp of whats going on. I can’t give you exact numbers, I have no idea what you are using, “standard” isn’t really a thing here too many variables, bit type/material/geometry included.
    <50% stepover, try not to slot cut use peel, adaptive or tricoidal instead. Plunge rate, 2-5mm/s, Rapid, <8.4mm/s. Feed Rate, hard to say, you have to do test cuts to find out, slotting will be at least half the speed of a peel or adaptive, 5-12mm/s depending on depth of cut 2-5mm?
    I’m starting to slowly build up this page. This isn’t a fully assembled machine so I can’t give you a number to use, you will have to experiment, sorry.
    Milling Basics
    #46347
    Larry McCaughn
    Participant
    What I call a “standard” MPCNC is your “Mostly Printed Parts CNC Bundle” with a DW660 router using USA EMT  and have successfully modified the brackets that hold the z-axis tubes together after the originals broke at the screw holes. But it is still basically the way I purchased it.
    And I have used an 1/8th up cut end mill making a dozen or more projects involving “part”, “hole”, and “carve” type cuts in pine planks and oak plywood up to 3/4′ wide or the “part” cuts.
    But I appreciate your response.
    #46349
    Ryan
    Keymaster
    The size of your machine is the biggest fact in depth of cut and feed rate.
    I would say stick with whatever you use for the 1/8″ but go 10% slower to start and tune from there.
