0.6mm nozzle settings
New Home Forum LowRider Advice – LowRider 0.6mm nozzle settings
This topic contains 2 replies, has 2 voices, and was last updated by  Ryan 1 day, 12 hours ago.
Viewing 3 posts - 1 through 3 (of 3 total)
  • Author
    Posts
  • #110145
    Rob
    Participant
    Got myself some fluorescent green and a 0.6mm nozzle. First print with this nozzle and settings. Some show and tell to inform others. Ender 3 with a Swiss micro all metal clone.
    Print feels very solid and strong. 41grams, 13.64m
    Settings:
    Layer height: 0.4mm
    Line width: 1.0mm (no type, 1.0mm)
    Perimeters: 2mm
    Top/Bottom: 2mm
    Infill: 50%
    Speed: 50mm/s
    Time to print: 1h30m
    Holes have to be drilled a little bit.
    • This topic was modified 1 month ago by  Rob.
    1 user thanked author for this post.
    #114834
    Rob
    Participant
    Short update:
    only the bigger parts are suitable to be printed with these settings, the smaller parts are better printed at normal 0.4mm nozzle settings. The difference in print time with smaller parts also doesn’t get you a much shorter print time.
    And then you open up your second roll of fluorescent green from the same brand with the same article number and it is a completely different color and needs different print settings, see picture. And the shop ignores your complaints. Time to find another supplier.
    #114966
    Ryan
    Keymaster
    Wow I have seen differences in color before but that is pretty drastic.
